Vehicle overheats after changing timing chain cover?
Old Jun 7, 2017 | 07:55 PM
Reyes1995's Avatar
Reyes1995
Default Vehicle overheats after changing timing chain cover?
I am having trouble with my truck overheating and pushing coolant back into the overflow after replacing the timing chain/cover. has gurgling noise from top hose after sitting for awhile. Is there just excessive air the system? Or??? Any advice would be greatly appreciated.
Old Jun 7, 2017 | 08:30 PM
mantisman51's Avatar
mantisman51
They are notorious for getting air trapped and having to be "burped". Is there heat when you turn your heater on high? A lot of times you'll get very little heat out of your hvac due to air being trapped.
Old Jun 7, 2017 | 08:40 PM
dbbd1's Avatar
dbbd1
Did you replace the thermostat too? Maybe it's in upside down.
Old Jun 7, 2017 | 09:20 PM
Reyes1995's Avatar
Reyes1995
I used a vacuum bleeder to get a good amount of the air out. And the vehicles did have a good amount of heat with the temperature at around 230 degrees. I did replace the thermostat and put it in the way it came out, with the spring side down
Old Jun 8, 2017 | 06:10 AM
Moparite's Avatar
Moparite
Drill a hole(1/8) in the t stat, It will let the air out when you fill it. Must be a hundred posts a on this same subject. Read post #14!
https://dodgeforum.com/forum/2nd-gen...p-bleed-2.html
