Track Bar Bushing
Old Jun 9, 2017 | 11:09 PM
MasonArmstrong's Avatar
MasonArmstrong
Default Track Bar Bushing
So i have a 98 ram 1500 4x4 with a bad track bar bushing. Is it a 1 piece or 2 piece bushing? All the auto parts sellers have both and i dont want to buy the wrong parts. Also, whats the best method to get the old bushing out?
Old Jun 10, 2017 | 10:11 AM
How is the other end of the track bar? Might be easier to just replace the whole thing.
Old Jun 10, 2017 | 10:34 AM
MasonArmstrong
The other end is fine, Only the bushing is bad
Old Jun 10, 2017 | 10:40 AM
Looking at the various offerings, I think either flavor would work, the two-piece fellers are just easier to install.
You can press the old one out, or, barring that, cut it up, and take it out in chunks.
Old Jun 10, 2017 | 11:34 AM
dbbd1's Avatar
dbbd1
I'll just shut up now,
Wrong "bar"
Old Jun 10, 2017 | 12:48 PM
AtomicDog's Avatar
AtomicDog
That OEM track bar is famous for going bad at the ball joint end. If you plan on keeping the truck awhile, this might be the best time to upgrade it to the 3rd gen style track bar that has bushings at each end. To use that style track bar, you would need the conversion bracket. Here is a video of the procedure -
Old Jun 10, 2017 | 04:17 PM
MasonArmstrong
Originally Posted by AtomicDog
That OEM track bar is famous for going bad at the ball joint end. If you plan on keeping the truck awhile, this might be the best time to upgrade it to the 3rd gen style track bar that has bushings at each end. To use that style track bar, you would need the conversion bracket. Here is a video of the procedure - https://www.youtube.com/watch?v=FJmqmjC1Y-w
The video is of a ram 2500, will the same go for my 1500?
Old Jun 10, 2017 | 07:03 PM
Yep. They make brackets for all of 'em.
Old Jun 10, 2017 | 11:36 PM
AtomicDog's Avatar
AtomicDog
The biggest thing to check for regarding the bracket that I've noticed is that some are tailored to account for non-stock lift heights. Other than that, the bracket should be the same.
Old Jun 11, 2017 | 10:09 AM
AtomicDog's Avatar
AtomicDog
Here is a complete conversion kit, which includes the bracket, an adjustable track bar and all of the needed hardware.
https://www.hellbentsteel.com/shop/p...bar-1994-2002/
