01 1500 stall issue
Old Jun 13, 2017 | 03:57 PM
JSquared's Avatar
JSquared
Default 01 1500 stall issue
I have an 01 ram 1500 5.9. It runs fine in park and nuetral, but as soon as you put it in any gear it dies. I have cleaned the throttle body and the iac motor. I am at a loss as to what it would be. I have also had some issues with the truck not wanting to shift. I have replace both the silinod and sensor in transmission already too. Thanks
Old Jun 13, 2017 | 04:15 PM
Can you keep the engine running if you feather the gas? Do you feel it jerk when it dies? (like dumping the clutch in a manual trans car?)
Welcome to DF!
Old Jun 13, 2017 | 04:21 PM
JSquared's Avatar
JSquared
Yes to a reasonable extent.
Old Jun 13, 2017 | 04:25 PM
JSquared's Avatar
JSquared
It's runs just fine in park and neutral but just dies in all gears
Old Jun 13, 2017 | 06:11 PM
Some folks have solved that one by replacing the crank sensor. Why it works, I have not a clue... but, it does. Get one from the dealer. Yes, they are more expensive, but, they actually work the way the PCM expects. More than I can say for some of the aftermarket fellers.
Old Jun 15, 2017 | 10:07 AM
JSquared's Avatar
JSquared
I replaced the crank sensor. Is there anything else that might cause this issue. Thanks
Old Jun 15, 2017 | 10:41 AM
And what brand did you put in this time?
