99 dodge 1500 overheating
Old Jun 21, 2017 | 04:23 PM
TheMercifulCOW's Avatar
TheMercifulCOW
Question 99 dodge 1500 overheating
Ok so i got a 99 Dodge 1500 5.2L V8 2WD. I for the life of me can't quit getting it to overheat when i turn on the AC and i am idiling. If i have the AC off its fine and will never overheat. Also if i have the AC running but don't stop for a long period it won't overheat. But if i just sit there and run the AC it will get up to 250 within 5-10 minutes.
Things i have replaced.
Water pump
Thermostat
Fan Clutch
All hoses
Radiator flushed and refilled
Also heard a lot of people saying that the AC will blow hot when they are having it overheat but mine continues to blow cold even when overheating. Also if i turn on the heater when it starts and rev the engine to about 2-3k rpm it will cool down and return to normal temperature range.
I am at my wits end here on where to go now as i have replaced almost everything i can think of.
Old Jun 21, 2017 | 07:03 PM
I would be tempted to put a IR thermometer on the radiator, and see if you have cold spots. A flush won't necessarily clear clogged tubes.
Welcome to DF!
