Found this in my transmission pan
Old Jun 26, 2017 | 09:04 PM
Gatorgman's Avatar
Gatorgman
Default Found this in my transmission pan
so I noticed my truck was shifting a bit rough in lower gears (mostly 1sr to 2nd) so I went to change the fluid in the pan and found these three pieces sitting in my pan. No idea what they are or where they go the metal posts appear to be shearaed off on the ends and one is visibally broken on one end. As for the small barrel(?) it feels light for its size. Is not magnetic and is very slightly thinner at the ends. Any help would be very much so appreciated
Old Jun 27, 2017 | 06:48 AM
Moparite's Avatar
Moparite
Over running clutch! Hope it's not the one in the back of the case. This is what can happen when they go.
Old Jun 27, 2017 | 09:31 PM
Gatorgman's Avatar
Gatorgman
Any idea where I can get a replacement kit? I think it's a tcc boost valve. Haven't had any luck finding the kit
Old Jun 27, 2017 | 09:58 PM
Need to rebuild the trans to fix that one.
Old Jun 27, 2017 | 10:35 PM
Gatorgman's Avatar
Gatorgman
Are you sure?? It's just the spring retainer that broke. I know I have to rip apart the trans. Would love to avoid purchasing a full rebuild for such a small part
Old Jun 28, 2017 | 09:08 AM
No, but, I am fairly confident. If that roller in your pick is from one of the one-way clutches, it's only a matter of time before you get a serious failure, and grenade the trans.
Old Jun 29, 2017 | 08:59 PM
Gatorgman's Avatar
Gatorgman
After a lot of painful research the parts I need can all be found in shift kit. That's to those whom replied! Much appreciated
