LED 3rd brake light won't turn off when truck is off
Old Jul 9, 2017 | 08:16 PM
dbbd1's Avatar
dbbd1
Originally Posted by cedric green
There was know wiring needed when installling the light it just plugged right into the stock connector
Yes, something is wired up wrong. Yours is a 2001, maybe you got a unit for 97 or below. Between 97 and 98, the wiring changed from switching the positive power to switching the ground. Maybe your problem???
Old Jul 9, 2017 | 09:47 PM
cedric green's Avatar
cedric green
oh ok so ignore I pretty much just swap the ground to the positive and the positive to the ground that should fix the issue ?
Old Jul 10, 2017 | 06:23 PM
Moparite's Avatar
Moparite
Nope , they still stay on when the headlight switch is off
Just to be sure you are turning the **** to shut off the cargo light not the headlights correct? Switching the wires will reverse polarity and may blow the fuse. Led's usually have diodes in them to protect from reverse polarity(if not they will blow). I would contact who ever you got it from.
Old Oct 20, 2017 | 06:15 PM
uw1919's Avatar
uw1919
Just got a new third brake light and I'm having the exact same problem.. did you ever find out how to fix it?
Old Oct 20, 2017 | 07:00 PM
Dodgevity's Avatar
Dodgevity
Put the old light back in to see what happens. You may need to add a resistor. LED lights can light with such little current, that any type of voltage drop may activate them.
Old Mar 10, 2018 | 06:09 PM
Bob LaVasseur's Avatar
Bob LaVasseur
I am having the same problem just bought an aftermarket LED light and no matter what I do it's stays on
Old Mar 11, 2018 | 04:49 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
What you have to do is cut the two cargo light wires and solder then to the opposite color I went through this. So let's say (colors vary this is an example) you have a yellow and red wire for the cargo lights, cut both of them, and solder yellow to red and red to telling and that will fix your problem.
Old Apr 22, 2018 | 01:51 PM
David Wade Pigott's Avatar
David Wade Pigott
Default 3rd brake light
So did that fix the problem by swapping the 2 Cargo wires
Old Apr 23, 2018 | 02:35 AM
MoparFanatic21
It should have went through the same thing.
Old May 1, 2018 | 10:05 PM
BrownBomber's Avatar
BrownBomber
I have the same problem. Switched the cargo lamp wires and it did not fix it.
