Where is engine serial number
Old Jul 19, 2017 | 06:51 PM
Needofhelp's Avatar
Needofhelp
Default Where is engine serial number
I have a 97 dodge ram van b2500 5.9l, i need help finding the engine serial number, ive already found the casting number
Old Jul 19, 2017 | 06:55 PM
There isn't one. Why would you need it?
Welcome to DF!
Old Jul 19, 2017 | 11:07 PM
Needofhelp's Avatar
Needofhelp
The van wont turn over, ive changed all other possible parts that could cause no spark other than the pcm, so I ordered a pcm and they cannot program it without knowing if an engine swap has been done. The reason they asked is because the part number on the pcm came back as a dodge Dakota not a b2500 ram van, i just got the van a few years ago at 297,000 miles so I don't know all that has been done, how could i tell if the engine has been swapped
Old Jul 20, 2017 | 06:39 AM
Moparite's Avatar
Moparite
Look on the side of the block the displacement(318-360) will be cast into. You can also look up the casting #. If you are getting another pcm find the correct oem # on it. You can look at what it was used for with it.
Old Jul 20, 2017 | 07:48 AM
Yeah, the PCM only really cares about the engine displacement. I.E. You don't really want programming for a 360, if you actually have a 318.....
Old Jul 20, 2017 | 06:35 PM
Needofhelp's Avatar
Needofhelp
Thank you guys sooo much i really appreciate the help, so all i need to tell them is that it's a 360 engine?
[img]webkit-fake-url://52034826-4338-4aa6-b103-2c426b4a8149/imagejpeg[/img]
Old Jul 20, 2017 | 06:36 PM
Needofhelp's Avatar
Needofhelp
I don't think the picture loaded but it says 360 after the other longer number
Old Jul 20, 2017 | 06:37 PM
Needofhelp's Avatar
Needofhelp
Old May 16, 2020 | 08:49 PM
Jwill541's Avatar
Jwill541
Did you just give them that number for the pcm? I am needing a pcm upgrade. I have a 98 that had a 5.2 and now has a 01 5.9 but can’t seem to find the serial number just casting numbers
Old May 17, 2020 | 07:48 AM
Because there is no serial number on the engine. The pic above shows a PART number, and displacement.
You don't need to replace your PCM, you need to get it flashed for the larger engine. Dealer should be able to do it, or, buy a tuner from one of the assorted companies that offer them.
