96 ram 5.9 speedo not working
Old Jul 29, 2017 | 12:40 PM
Serial number is build date.... November 21 1998......
What is the shift pattern on your t-case?
Old Jul 29, 2017 | 12:45 PM
Jlb.2569's Avatar
Jlb.2569
So now this is all starting to make sense. I got the truck of this guy and needed a trans. So instead of letting him put it in, i did cause i didnt trust him to do so. So hes lied to me and made me believe it was all the same. So is there anyway to get the speedo to work without having to find and swap again?
Old Jul 29, 2017 | 12:51 PM
Jlb.2569's Avatar
Jlb.2569
the shift pattern is different than the shifter shows. It shows 2h 4h n 4l. When i checked the t case when it was out goes 4h 2h n 4l. I suspected something wasnt right. And i have a harness hanging (3 pin) that has no where to go.
Old Jul 29, 2017 | 01:14 PM
Do you still have the original transfer case? All ya really need to do is swap 'em out, and you are golden. (and then you will have the VSS for that 'spare' connector to plug into as well.)
Old Jul 29, 2017 | 01:16 PM
Jlb.2569's Avatar
Jlb.2569
No unfortunately, he had already removed it before i got it.
Old Jul 29, 2017 | 03:48 PM
I would be tempted to call him, and see what he did with it.
