Oil Fouled Spark Plug - Cylinder 8 - 5.9L
Old Aug 3, 2017 | 01:53 PM
RVA SS's Avatar
RVA SS
Default Oil Fouled Spark Plug - Cylinder 8 - 5.9L
Fellas, I got a misfire code and pulled the faulty cylinder's plug. I pulled cylinder 2 to compare and below is the result comparing 8 vs. 2. Pretty nasty and the electrode is clearly evident of oil fouling and I plan on diving into a compression test to determine if it's rings or valve related. Or could it be something else?
I was curious about the browning on the ceramic insulator, I did some research and I guess there can be a compression leak on the plug and the browning is coming from escaping gasses from the cylinder. Any thoughts? Not too concerned on this but curious...
Old Aug 3, 2017 | 02:04 PM
Have you read this thread yet?
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Aug 3, 2017 | 02:46 PM
RVA SS's Avatar
RVA SS
Originally Posted by jkeaton
Thanks! Aside from the oil consumption I don't feel like the other symptoms apply... but if its been bad for a while I might be conditioned to poor performance.
Also, the tech article mentions a carbon fouled plug and my plug isn't exactly carbon fouled. I did have a CEL a while ago for o2 sensors and I cleared it and it never came back...
Not dismissing the plenum but maybe this is the start or the consequences starting to show. I've got 128k miles...
Old Aug 3, 2017 | 03:16 PM
Wouldn't hurt to have a look.
Do you get any blue smoke at startup?
Old Aug 3, 2017 | 04:06 PM
RVA SS's Avatar
RVA SS
No blue smoke, given how easy it is to test the plenum I might as well take a look. I actually hope it is the plenum, I'd much rather spend the $160 for the Hughes Plenum kit (or even splurge for the Air Gap intake) opposed to worrying about heads or rings...
Old Aug 4, 2017 | 05:52 AM
Dodgevity's Avatar
Dodgevity
Replace the plugs and torque properly with a torque wrench. Try not to pull it out again, unless something goes wrong, or you're at the next replacement interval. Worry about it only if the problem returns.
Looking at the crush ring, it looks less compressed than the other plug.
