94 1500 5.9 dying
Old Aug 3, 2017 | 09:50 PM
Mattmays94's Avatar
Mattmays94
Default 94 1500 5.9 dying
I had a freeze plug blow in the back part of the engine. Me and a friend dropped the tranny, replaced freeze plug, easy fix. Hooked everything back up correctly, and now it idled very rough and dies when I put it in any gear. I had a few fuel injectors I needed to replace so I thought it might be that, I replaced them, and a distributor cap which was cracked, and still it runs terrible and keeps dying. It is also backfiring for some odd reason to which I don't know. No crossed plug wires, spark plugs are fine, I'm pretty sure it's not the timing because we didn't really mess with the timing that I know of. If anyone has any information on how to fix or troubleshoot I would GREATLY appreciate it. Getting very tired of messing with this old truck.
Old Aug 3, 2017 | 10:18 PM
Welcome to DF!
Right behind the passenger side head, between the block, and trans, is the crank position sensor. They tend to get destroyed if folks R&R the trans without removing it first. I would start by pulling it out, and having a look. You have all the symptoms of a broken sensor.
Welcome to DF!
Old Aug 4, 2017 | 12:33 AM
44dakota's Avatar
44dakota
definatly agree with hey you, and to go a step further, that crank sensor is triggered by the windows on the outer diameter of the flexplate, i hope you didnt use a long screwdriver in those windows to to rotate the engine over to get the bolts out, if so, you may have( warped ) or messed up the tolerance required for the trigger point..
Old Aug 4, 2017 | 06:52 PM
Mattmays94's Avatar
Mattmays94
I replaced the crank sensor before we put the transmission back in because the wires were starting to come out of the harness. So It's got a brand new crank sensor.
Old Aug 4, 2017 | 07:06 PM
Was it in there when you installed the trans? If it was, then you need to check it.
