tranny problems
Old Aug 7, 2017 | 12:45 PM
Kyle224's Avatar
Kyle224
Default tranny problems
I'm New to.all this but having problems with my 1999 1500 sport 4x4 was hoping some.one could help.. couple days ago I was driving.down the high way and my drive shaft stoped, bad u joint. Well once I got.it home and changed the u joints I drove it.around and it seems that first gear isn't working properly. Have to give it a Lot of gas to get it to move.. And if I manually put it in first gear and try to go it's like I'm pushing the gas and the break at the same time. I'm baffled any help would. E appreciated thanks
Old Aug 7, 2017 | 12:57 PM
Not in 4 wheel drive are you?
Old Aug 7, 2017 | 01:35 PM
Kyle224's Avatar
Kyle224
No not in 4x4, it's automatic tyranny and when I put the gear shifter all the way down into first gear the truck barely wants to move and soon as I let off the gas the truck stops like my foots on the break, but it's not
Old Aug 7, 2017 | 01:40 PM
Jack up the rear, trans in neutral, and spin the back tires. Feel any binding there? (be sure and try and spin the driveshaft as well.)
Old Aug 7, 2017 | 02:18 PM
Kyle224's Avatar
Kyle224
I'll give that a try.tonight.after work.. the weird thing is.too all the.other gears work.Just fine
