pulling abs codes
Old Aug 8, 2017 | 11:14 AM
Cholmes's Avatar
Cholmes
Default pulling abs codes
Hi, I have 02 2500 and getting abs lights, I have replaced one sensor in the front and the light went out until I stepped on the brake, Now it is back. I have searched but can't find anything that is specific but how to pull abs codes. Is there a way? I know some can't be pulled. I have a pretty good scanner but it revealed nothing.
Old Aug 8, 2017 | 12:07 PM
How is the brake line going to the rear of the truck? That sounds more like a line failure, than an ABS problem......
Old Aug 9, 2017 | 07:45 AM
Cholmes's Avatar
Cholmes
The brakes are fine, all new in fact. The speed sensor was damaged by the rotor and triggered an ABS light. I left it that way for a long time (just unplugged it) and recently put a new sensor on. Lights went out then back on the first time I stepped on the brake.
Old Aug 9, 2017 | 07:52 AM
You will need a specific ABS code scanner to pull ABS codes. OBD scanner wont work.
