Overheating
Old Aug 13, 2017 | 03:20 PM
Jbrock123's Avatar
Jbrock123
Default Overheating
I have a Dodge Ram 1500 1996 it has a overheating problem it used to hit 260 but now stops about roughly 245 max. I change the thermostat and housing water pump cool temp switch flushed radiator! No signs of blown head gasket besides the overheating is there anything else I can do??
Old Aug 13, 2017 | 03:58 PM
Replace the radiator.
Welcome to DF!
Old Aug 13, 2017 | 04:42 PM
Jbrock123's Avatar
Jbrock123
Could it still be the problem even if I flushed this one?
Old Aug 13, 2017 | 07:19 PM
Flushing it doesn't imply that it actually did any good. The water/chemicals just flows thru the areas that actually still flow. If you have clogged tubes, the flush stuff on the market today isn't going to clear it out.
Old Aug 13, 2017 | 09:32 PM
Jbrock123's Avatar
Jbrock123
Good point I will replace it tomorrow and see what happens thank you!
