1997 318: What are the Factory Compression PSI #'s
1997 318 222,322k
My compression #'s
Back of Block
125 120
130 135
134 140
130 130
Front of Block
Are these reasonable psi#'s
What was the psi from the factory?
My compression #'s
Back of Block
125 120
130 135
134 140
130 130
Front of Block
Bit of a wide spread, but, still mostly 'acceptable'. Most OEM's don't want more than a 10% spread from highest to lowest. You are a bit more than that. Might not hurt do do a wet test as well, or leakdown test, to see where your compression is going. Not sure there actually IS a stock spec for compression.....
