All of a sudden bad/rough idle (video included)
Hi all, new member from Sweden!
So got myself a ram gen 2 1999 with a 5.9 litre magnum. Was running perfect when i got it, now 1500km later its starting to run bad on idle / highway cruises.
First thing i did when i got the truck was complete tuneup, changed all the oils in driveline and also changed both o2 sensors and IAC sensor. Did a complete cleanup of the throttle body, there was NO oil in the plenum. Drove it like this for some months. Last weekend i took it for a 700km drive.
After a few km the check engine light flashed after the engine got abit hesitant for a second or two. The exact same problem came back few times on the trip. When i got home i checked the code and it said P0308 and p0132 (missfire on 8th cyl) and (o2 sensor circuit high voltage (bank 1 sensor 1)
Now the idle is bad when engine is warm. (see video) no ide why the sound got all messed up.
https://www.youtube.com/watch?v=d6S6...ature=youtu.be
Any ideas what may cause this?
100% agree from experience.. my truck HATED the aftermarket sensors I installed
and I have since replaced with GENUINE Mopar
Was at the garaget today and reinstalled the original sensors, truck will now run on idle but throws a code (p0132) Hopefuly the mopar sensors will fix this.
Ill update when they arrive, problem with living in sweden is the 2-3 week order time from US.
If it a BIOTH p0132 and p0138 your O2 sensor fuse is blown. You have a sensor with exposed wire, it has shorted and blown the fuse. One of those two sensors caused it. Replaced the sensors? GOOD. Now go replace the blown fuse.
