Ac system dashboard vents
Old Aug 18, 2017 | 01:40 PM
Rammit82's Avatar
Rammit82
Default Ac system dashboard vents
Ive been researching it and i think it might be the recirc door but when my ac is on everytime i step on the gas pedal enough to accelerate the forward vents stop blowing and the defrost and floor vents blow instead until i let off the gas enuff and it starts blowing out the forward vents again. Any advice would help.
Old Aug 18, 2017 | 02:40 PM
So a search in the FAQ/DIY section for "wild vents". The fix is cheap and easy.
Old Aug 18, 2017 | 04:20 PM
Rammit82's Avatar
Rammit82
I looked around and couldnt find the post for it.
Old Aug 18, 2017 | 05:17 PM
Apparently, need to expand the search..... Try this thread. (video.)
Old Aug 19, 2017 | 01:34 AM
Shadow_Death's Avatar
Shadow_Death
This reminds me, I need to yank my controller out. My vents will only blow through the floor and/or the defrost vents but not the dash at all. I've had to find and replace that little slider inside once because on the factory piece the rubber rolled off of it and didn't make good vacuum seals.
Old Aug 19, 2017 | 08:56 AM
Moparite's Avatar
Moparite
Replace your check valves! You have two i believe on your year one on the vac line port coming out of the plenum(passenger side in the middle) and the other near where the line goes into the firewall. You can get then at napa just make sure you check the flow direction before you put them in.
https://www.napaonline.com/en/p/NDP7301349
