Radio wiring question
Old Aug 23, 2017 | 10:11 PM
BrandonBuc'em's Avatar
BrandonBuc'em
Default Radio wiring question
I installed a pioneer AVH-3300NEX, NICE unit! Problem I'm having is when I turn to acc, I wait for all dash lights to go off and the fuel pump to prime and then maybe a second or 2 longer to crank... It's my ritual, if you will. The screen comes out during this time, but when I start the truck it loses power, screen goes back in and comes right back out because the truck is running at that point. I tried doing it faster and it still reboots it everytime.
I want it to stay on while starting. Anyone have ideas on how to accomplish this.
Old Aug 24, 2017 | 08:04 AM
Where do you have your power wire coming from?
Old Aug 24, 2017 | 11:18 AM
Ramman18's Avatar
Ramman18
All accessories turn off in the ignition switch so full power can turn over the engine when in start position. Every vehicle always does this. You're just finding it annoying on the aftermarket head units, as did I. Mine took forever to start up anyway then like 5 seconds to come back to life. Good thing some tweeker stole it. I love the stock CD player as it reboots much faster, just has little umph for wattage.
Only way around it is to wire separate power to the head unit. The ignition switch has several settings and that's what powers the dash so you'd have to circumnavigate it.
Old Aug 25, 2017 | 11:50 AM
brewman's Avatar
brewman
A time-delay relay that will maintain power temporarily when acc is switched off may work. You'll need to find a relay that resets the power-off timer if acc power is reapplied before the timer triggers shutdown.
Old Aug 26, 2017 | 12:53 AM
Maximillio's Avatar
Maximillio
THIS. Having done EXTENSIVE wiring, and being in a related field, (Completely rewired 5 channel amp and head unit replace, self installed 2-way remote start and alarm ect) I can ASSURE you this is working as intended. Its exactly as he said. When you turn over the truck, it cuts accessory power to provide optimal conditions for starting. On these trucks (as far as Im aware) they all have two wires, the key down accessory that provides power to just radio and related, and then the 'run' position that also powers AC, windows ect. You could check if the key down power gets cut (I assume it still would), but you would need to probe, just a thought since you'd never be able to notice in normal conditions :P Outside of the rare chance that worked (unlikely), you would need to find a way to have power still run there when you turn the key. You MAY be able to find another wire that would still stay on when you crank, and turn off with the key, but that could hamper starting. Best option would be to find a way to do what he suggested, but I would think its not worth the effort, to just live with it resetting, having spent days of time on my back soldering and probing in a completely removed interior.
Hopefully that's not too confusing to read, lots of information recalling and jumbling around in my head:P
Old Jun 25, 2018 | 07:22 PM
lwight's Avatar
lwight
Hey Brandon, I'm thinking of buying this radio for my 2nd Gen Ram. Looking at the dash, I worry that the flip up will interfere with the heat/air vents just above the radio slot. Is this a problem for your installation?
Thanks,
Larry
Old Jun 27, 2018 | 03:59 AM
BrandonBuc'em
Thanks,
Larry
I wouldn't say I regret buying this radio, I've had for some time now. It was an impulse buy, I for some reason had to have the android radio. Anyway, onto your question it interferes with the cup holders, the fog light and o/d switches. But besides that, no other interferences. Keep in mind I have 97, in 98 they changed the dash. Yours may be different. Hope this helps
Old Jun 27, 2018 | 09:49 AM
lwight's Avatar
lwight
Brandon! Thanks for replying. I sure appreciate it. And I appreciate an impulse buy! 24 hours earlier I bought one on EBay! Thanks again.
Larry
