Running out of ideas on BRAKE + ABS light
Old Sep 2, 2017 | 01:07 PM
Dodgesweden's Avatar
Dodgesweden
Default Running out of ideas on BRAKE + ABS light
Hey guys.
So the problem has been there since i got the truck 4 months ago. ABS + BRAKE light shines up when i pass 40mph.
Did alot of reading and ordered the rear axle sensor..
Few weeks later i got the sensor and replaced it with no change, still ABS + BRAKE at exacly 40mph.
Did some more reading and ordered a ABS module unit, replaced it.
Now its more random, sometimes i wont light up at all and sometimes at 40 to 50mph.
Wierd thing is if i do a quick restart while truck is rolling at 30mph~ and the ABS+BRAKE lights turn off it wont come back til i stand still and restart the truck.
Any ideas what the problem is? Its a rear only ABS.
Old Sep 2, 2017 | 02:44 PM
brian102's Avatar
brian102
do you have rear wheel or all wheel abs? if you have a scanner capable of reading real time data, set it to display wheel sensor data and keep an eye on it while driving. if there's a sensor issue you'll know. i went through 3 sensors, 2 were bad right out of the box, before i finally fixed mine.
Old Sep 2, 2017 | 04:04 PM
Dodgesweden
Its a rear only ABS. Well since The speedometer is working there gotta be something wrong with the ABS system. Problem is i cant find anyone with a scanner for ABS.
Old Sep 2, 2017 | 04:08 PM
What year is your truck?
Old Sep 2, 2017 | 04:26 PM
Dodgesweden
1999 4x4
Old Sep 2, 2017 | 10:19 PM
You need to read codes, and see what it is whining about. If you got a cheap, aftermarket sensor, that may still be the problem.
Old Sep 3, 2017 | 12:28 PM
Dodgesweden
Gonna call the dodge mechanic tomorrow!
I did some more digging and since i got the truck its been equipped with a Tekonsha envoy, its some sort of towing brake?
Was gonna order a new brake switch and see the picture, someone has cut off half of the wires?
Attached Thumbnails Running out of ideas on BRAKE + ABS light-21389236_1454544731265748_1172058911_o.jpg   Running out of ideas on BRAKE + ABS light-21363442_1454543141265907_921827270_o.jpg
Old Sep 3, 2017 | 01:57 PM
That would likely annoy the ABS system. Probably a few others as well. If you have the service manual, take a look at where those wires are supposed to go, and see if you can find the other ends....
