00 1500 transmission drives in neutral now after putting tranny back
Old Sep 4, 2017 | 04:00 PM
comet424's Avatar
comet424
Default 00 1500 transmission drives in neutral now after putting tranny back
ok I fixed the gas tank issue just stuck rtv sealant in that pipe
but I finally got the transmission back up into the truck and added about 7 litres of tranny fluid to the transmission
it didn't wanna go at first the tranny and when I shoved it in park engine stalled
started it back up ad stuck in reverse she started to move...
now sticking in neutral it drives forward.. in D 1 2 3 drives forward... in Reverse and N you can hit brakes and stops vehicle... in D 1 23 u hit brakes and it keeps driving the wheels.. and I'm still on stands ... so what gives here what the hell is wrong now.. that its now driving in neutral?
Old Sep 4, 2017 | 05:28 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Linkage sounds like it's messed up.
Old Sep 4, 2017 | 05:53 PM
comet424's Avatar
comet424
I had friend pop over and he said it will always run in neutral when its jacked up off the ground...
he held it and when I put in gear it didn't move but when you let go it started to move
but never tried reving engine
Old Sep 5, 2017 | 03:00 AM
MoparFanatic21
The wheels shouldn't move when in neutral and the brakes pressed...
Old Sep 5, 2017 | 08:45 AM
comet424's Avatar
comet424
it doesn't when you first hold brakes you let go and then starts to spin slowly he said that's normal on the truck
Old Sep 5, 2017 | 08:47 AM
And he is correct. Even though nothing is mechanically linked, there is still a bit of friction on all the parts in the trans, so, if there is no load, things will indeed spin.
Old Sep 5, 2017 | 11:59 AM
comet424's Avatar
comet424
oh ok thanks
I was worried I was like I never seen this on my cars before but on truck its my first transmission job...
now I got a new post I having crossmember installation problem
