Transfer case
Old Sep 6, 2017 | 11:06 AM
Chevierd's Avatar
Chevierd
Ok thank you for the help
Old Sep 6, 2017 | 06:57 PM
Nv242d? Nv231d?
Old Sep 8, 2017 | 09:21 AM
Chevierd's Avatar
Chevierd
My truck is throwing a code for air\fuel solenoid. Does and body I have a idea what that is or what could be causing that code.
Old Sep 8, 2017 | 09:30 AM
What code?
Old Sep 8, 2017 | 05:08 PM
Chevierd's Avatar
Chevierd
P0505
ifor air control motor circuit
Old Sep 8, 2017 | 06:31 PM
Failed PCM, Bad IAC valve, bad wiring to the IAC, bad connection at the PCM..... May even be as simply as a dirty throttle body.
Old Sep 8, 2017 | 09:55 PM
Chevierd's Avatar
Chevierd
Do you know how much voltage is supposed to be at the connector for the IAC
Old Sep 8, 2017 | 10:13 PM
12 volts on at least two of the pins.
Old Sep 13, 2017 | 08:49 AM
Chevierd's Avatar
Chevierd
Does any one know if I by a PCM if I can get from a junk yard or if I have to get if from somewhere where they marry it to you VIN
Old Sep 13, 2017 | 10:14 AM
You can get one anywhere you want, however, it does need to be flashed to the correct VIN. Dealer, or any shop with a good scan tool can do it.
