Transfer case
Old Sep 5, 2017 | 08:30 PM
Chevierd's Avatar
Chevierd
Default Transfer case
I have 2000 rt 4x4 durango. It has the manual. The shift can move with no force to it in any gear. It will not ingauge to and 4x4 mode. Can anyone help as to what could be wrong. Thank you
Old Sep 5, 2017 | 10:03 PM
Check the linkage.
Old Sep 6, 2017 | 06:43 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1, sounds like the rubber bushings in the linkage disintegrated, they tend to do that when they get old, hopefully you didnt lose the linkage (uncommon, but possible)
Old Sep 6, 2017 | 06:51 AM
Chevierd's Avatar
Chevierd
The linkage is still there. If the rubber bushing are bad would I still be able to crawl under the truck and still be able to manually shift it to 4x4?
Old Sep 6, 2017 | 10:04 AM
Have someone else move the lever, while you watch and see what the linkage is doing.
Old Sep 6, 2017 | 10:07 AM
Chevierd's Avatar
Chevierd
Ya I did that. It moves with the lever it just won't shift in to any of the gears
Old Sep 6, 2017 | 10:17 AM
JeeperDon's Avatar
JeeperDon
There should be clunking going on in the t-case when you move the lever. Is that happening? If you look at the tear down of the t-case in the FSM, you can see it's just one rotating part that shifts two forks (one hi/lo and the other 2/4). If the main exterior lever is moving to all the positions and yet it's still not shifting, it's kinda not possible to do that unless something is broken inside.
Old Sep 6, 2017 | 10:19 AM
Chevierd's Avatar
Chevierd
Thats what I was think because its all loose
Old Sep 6, 2017 | 10:47 AM
Chevierd's Avatar
Chevierd
Does any one know what transfer case it is
Old Sep 6, 2017 | 11:03 AM
JeeperDon's Avatar
JeeperDon
Read the round tag in the back.
