Tranny Issues?
Old Sep 7, 2017 | 02:22 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Tranny Issues?
Here's the story lol I did a tune up (new spark plugs, wires, distributor, and rotor) on my truck. Next day go out to drive it and it's good until you let off the gas then it doesn't shift and when you go to pull out it takes off in second. Take it out of drive and put it back in it shifts until you let off the gas and it won't shift and pulls out in second. What could cause this? Fluid is good had some bubbles in the fluid. I am not a tranny man I can rebuild them (only did one when I was way younger) but I can't believe it would do that without any warning. Plus it worked fine one day the next it did this. No codes either.
Old Sep 7, 2017 | 02:23 AM
MoparFanatic21
Sorry forgot to say 96 360 46re
Old Sep 7, 2017 | 09:01 AM
When's the last time it had a fluid/filter change/band adjustment? If it's been a while, might start there. While you are in there, changing the governor stuff may not be a bad idea either. Go with the Borg Warner heavy duty solenoid set. They are available from various vendors on Ebay for around 100 bucks.
Old Sep 7, 2017 | 10:19 AM
99sportram's Avatar
99sportram
I agree with HeyYou, if it is taking off in second it sounds like it's in limp mode. Do you have O/D? Also if you know somebody that has a scanner have them hook up to it to check the governor pressure reading and see if it has any intermittent codes. Sometimes it won't throw the light if the symptom does not trigger 3 times in a row or if you have a couple good starts in between issues.
Old Sep 7, 2017 | 10:23 AM
99sportram's Avatar
99sportram
Also if you were doing work under the hood check this cable.
https://dodgeforum.com/forum/2nd-gen...lve-cable.html
It wouldn't cause limp mode and normally affects higher gears/throttle but the shifting you are describing as far as letting off the gas sounds like an improper adjustment. You may have just bumped it or loosened it.
Old Sep 7, 2017 | 12:44 PM
MoparFanatic21
That's what I'm going to do after work today. I would have to think of it's anything major it would set a code
Old Sep 7, 2017 | 12:45 PM
MoparFanatic21
I'll have to use my scanner and see
Old Sep 7, 2017 | 12:50 PM
MoparFanatic21
I will give that a shot to see if that's it. I thought I checked it but it was dark with a flashlight in my hand lol
Old Sep 9, 2017 | 02:42 AM
MoparFanatic21
UPDATE: My truck is Christine. It fixed itself! Still plan on filter/fluid replacement.
