Help -Gear Ratio
Old Sep 9, 2017 | 11:30 PM
Sarah Wooden's Avatar
Sarah Wooden
Default Help -Gear Ratio
So I got a question! I am trying too figure out the gear ratio for the front axel for a 1998.5 3500 cummins 4x4. The parts sticker under the hood of the truck has been ripped off. The truck has 143,262 miles and at 70 MPH the RPMS range from 2300-2500! I've been looking on Google and it said that for 1997-2001 dodge 3500 Cummins have a Dana 60 for the front axels because of the 4x4. The GAWR is 4850. Can anyone please help me
Old Sep 10, 2017 | 10:17 AM
Go here, and get a build sheet for your truck. That will tell you what axle ratio it came with from the factory.
Welcome to DF!
Old Sep 10, 2017 | 10:33 AM
Sarah Wooden
Thanks. I also read you can tell by the numbers of your VIN the first three numbers of the VIN is 373..
Old Sep 10, 2017 | 10:35 AM
Nope. VIN numbers have nothing to do with it. Grab the build sheet, that is actually accurate information. (assuming nothing was changed after purchase....)
Old Sep 10, 2017 | 11:19 AM
Moved to the correct section.
