Codes for my 1997 Dodge ram
Old Sep 12, 2017 | 10:51 AM
jkbergin@sbcglobal.net's Avatar
Default Codes for my 1997 Dodge ram
My check engine light came on and I ran the code check with the key since I don't have a meter.
I got a 77 code and a 56 code which I can't find anywhere. The other codes were 12 and 25.
No 55 at the end. It ended with the 56 code. I did it three times to make sure I was not missing something.
any ideas?
Old Sep 12, 2017 | 11:04 AM
According to this,
http://www.troublecodes.net/dodge/da...gon-1996-1997/
77 is cruise control.
25 is the IAC
12 just means the battery has been disconnected within the last 50 ignition on-off cycles.
Here's an existing thread on 56, which does not exist.
https://dodgeforum.com/forum/2nd-gen...at-s-56-a.html
You can always double check by using a scanner instead of reading flashes. Any auto parts store will read the codes for free if you don't have a code reader/scanner.
Old Sep 12, 2017 | 11:15 AM
Thank you!
