replacement stock radio question
Subscribe
Sep 25, 2017 | 08:02 AM
ok I have found multiple replacement AM/FM CD-Cassette radios with 3 band EQs..
according to many ads I have read they all interchange BUT I have the infinity system
in my 97 so my question is WILL they all actually interchange or is the infinity 3 band EQ
radio a stand alone unit
some of the radios are RAZ units which I believe means they have the RDS system
Reply 0
Sep 25, 2017 | 03:10 PM
Quote: ok I have found multiple replacement AM/FM CD-Cassette radios with 3 band EQs..
The infinity door speakers have built in amplifiers so if you're planning on using the stock door speakers and wiring you'll want a head unit with either an amplifier trigger or antenna trigger output that will be connected to the wire that tells the built-in amplifiers to power-up. Otherwise, you'll need connect the built-in amplifier trigger to a switched 12v.
Reply 0
Sep 26, 2017 | 07:14 AM
Quote: The infinity door speakers have built in amplifiers so if you're planning on using the stock door speakers and wiring you'll want a head unit with either an amplifier trigger or antenna trigger output that will be connected to the wire that tells the built-in amplifiers to power-up. Otherwise, you'll need connect the built-in amplifier trigger to a switched 12v.
that's my problem.. I want a stock for stock replacement and want to be sure the one I buy is correct as I only want to pull the dash apart one time
Reply 0
Sep 26, 2017 | 08:42 AM
Quote: that's my problem.. I want a stock for stock replacement and want to be sure the one I buy is correct as I only want to pull the dash apart one time
Sorry, missed the part about wanting to keep the stock radio.
Reply 0
Sep 26, 2017 | 10:14 AM
Might hit up crutchfield. They can usually supply you all the adapters you need.
Reply 0
Sep 27, 2017 | 08:47 AM
Quote: Might hit up crutchfield. They can usually supply you all the adapters you need.
want to do a stock for stock swap out just need to make sure I correct unit
Reply 0
Sep 27, 2017 | 11:34 AM
Rebuilt/modified units sell on ebay. typically run 200 ea.
Each comes with a description specifying vehicle compatibility, include Infinity sys & Non.
I had planned on going this route until i realized that the factory amps went out.
Reply 0
Sep 28, 2017 | 06:59 AM
I can get a refurb with aux input for $160 but I don't want or need the aux input.. the other units
say fit from 94-2001 but do not specifically state infinity system and when I ask they aren't sure
and say well buy it and you can return.... uhhh yeah AT MY EXPENSE and as I said I only want to
have to pull the radio one time for replacement.. my dash is perfect and I would like to keep it
that way by not fudging with things
Reply 0
Sep 29, 2017 | 08:04 AM
truck got hit while parked yesterday so the radio is currently the least of my worries, thanks for any responses
Reply 0
Subscribe
