Head light assembly replacement
Old Oct 14, 2017 | 08:18 PM
Paulie 1959's Avatar
Paulie 1959
Default Head light assembly replacement
I managed to get old head light assembly out, but can not get new assembly in. I have a 1998 Ram 1500, SLT. How do I get new in place?
Old Oct 14, 2017 | 09:25 PM
frankie_b_jr's Avatar
frankie_b_jr
If it isn't fitting between the fender and the bumper, just loosen the bumper enough to let it sag down. After the lights are in you can use a jack and some wood to hold the bumper back up while you tighten it down.
Old Oct 20, 2017 | 01:32 AM
brian102's Avatar
brian102
if you're doing the whole thing like i just did [headlight and corner light entire assembly, i did the sport conversion] it's fidgety... there are 3 alignment pins, 2 are plastic and 1 is metal. the metal one kinda ratchets into it's hole and will hold the entire thing in just like the pins on the taillights... that was the pin i had a hard time lining up. also, dropping the bumper made life sooooo much easier.
