98 ram 1500 5.2 NO HEAT
Old Oct 19, 2017 | 09:38 AM
Drj3253's Avatar
Drj3253
Default 98 ram 1500 5.2 NO HEAT
hello I have a 98 ram 1500 5.2 with no heat. The heater core is new, new water pump, thermostat, etc. What else could cause little to no heat to come out of vents?
Old Oct 19, 2017 | 09:46 AM
Temp door cable hooked up?
Air pockets in the heater core. <- This is the most common problem......
Old Oct 23, 2017 | 09:41 PM
Spillage's Avatar
Spillage
Mine; the foam seal on the blend door had stuck the door to the box (years of no use).
Much cycling of the control finally broke it loose... and I got a shower of foam crumbs out of the vents.
