power stering problems
Old Oct 23, 2017 | 09:16 AM
That leaves the steering box itself. It's the only other part left. Assuming, that is, that nothing is binding in the steering itself.
Old Oct 23, 2017 | 11:45 AM
Ramman18's Avatar
Ramman18
When chasing my wander and loose steering, I started at the bottom price-wise and went up with all new parts. Turns out, the most expensive part was the culprit: the steering gear. Made it all perfect again. Of course, it took three trips and two gears from Redhead but it's finally good to drive again.
Old Oct 23, 2017 | 07:49 PM
pershingd's Avatar
pershingd
Yeah, but isn't it much more fun to walk into the parts store, and just empty your wallet on the counter?
Not in my universe it isn't. I bought a Tracker once without consulting the Boss. I spent the entire next year praying nothing went wrong or I'd never hear the end of it. I survived but have no desire to repeat the experience.
Old Apr 6, 2018 | 08:25 PM
cman9898's Avatar
cman9898
Update: i have replaced the entire system with no changes all the shops its been in have been scrathing their heads with no idea whats up. Im about out of options. Anyone have any ideas before i go swap out the box for a rack-pinion set and get the biggest pump i can find?
Old Apr 6, 2018 | 08:44 PM
What does your engine idle at?
Old Apr 6, 2018 | 09:39 PM
cman9898's Avatar
cman9898
About 8-900 rpm ive also got significantly more play in the steering wheel before it gets stiff but no wheel movement
Old Apr 6, 2018 | 10:30 PM
Ramman18's Avatar
Ramman18
Did you put in a Redhead?
If not, you haven't fixed the problem.
And find better "shops."
Old Apr 6, 2018 | 10:47 PM
cman9898's Avatar
cman9898
Unfortunatly redheads are sitting outside of my pruce capability... for now. Its definetly on the list
Old Apr 7, 2018 | 01:52 AM
Ramman18's Avatar
Ramman18
Well, they are a lot cheaper than a rack and pinion conversion!
Good grief, they're only $400 or so. You've wasted at least that taking it to shops I bet. So be patient and save up. I waited 10 years for my Redhead.
Old Apr 7, 2018 | 06:11 AM
Michael92's Avatar
Michael92
I agree with ramman18. Sounds like bad pump flow to me. Higher rpms increases 1 thing, pump/flow to rack and pinion or steering box. Depending on what you have. Low rpms mean would result in low pump pressure, making it harder to turn while not moving.
The 35s dont help the fact that your pump isnt pumping enough fluid to turn the tires. Just makes the sympton feel worse. I had a similar issue with mine and changed the fluid and tightened the worm gear adjuster on top. So far its Been alot better ! And even got rid of my pump whine, but that for me is just a short term fix.
