Track Bar help.
Old 11-10-2017 | 10:22 PM
MoparFanatic21's Avatar
MoparFanatic21
Default Track Bar help.
Went to replace my track Bar and it's been a nightmare. The stud bolt on the frame end was impossible to get off. Even my 750lbs impact gun couldn't touch it. Finally got the not off and it wouldn't come out of the taper. Well a 15 pound Sledge and a fork later it came out. Now here is where I'm stuck. The bolt/nut on the axle end. The not freely spins and I can't get a wrench on it. Any suggestions or did any of you have this problem?
Old 11-11-2017 | 04:27 PM
2bit's Avatar
2bit
It's been awhile since I changed mine. A picture would help. Can you cut the nut off, drive the bolt out, and then install it with a new nut and bolt? I'm not at home, I can't go look at mine. What year is your truck? 1500,2500, or 3500?
Old 11-11-2017 | 07:48 PM
I was able to get a wrench onto the nut from on top...... It was tight, but, manageable.
Old 11-11-2017 | 08:31 PM
MoparFanatic21
Hole is to small to cut it. 01 2500 with 1500 axles. I tried getting a picture but didn't turn out right.
Old 11-11-2017 | 08:32 PM
MoparFanatic21
Mine has no access on the top to get to the nut.
Old 11-11-2017 | 08:50 PM
Can you jam a punch, or something in there, to wedge it in place?
Old 11-12-2017 | 09:37 AM
MoparFanatic21
None that will stay. Here is my plan I'm going to tack weld the nut so it can't spin. Do you know where you can buy the flag nut?
Old 11-12-2017 | 10:15 AM
Lowes? Home Depot? Fastenal? (though they will probably want to sell you a package of ten.....)
Old 11-12-2017 | 10:51 AM
MoparFanatic21
Fastenal I tried a while ago and they said they don't sell those kinds of nuts. I will check Lowe's/Home Depot
Old 11-13-2017 | 02:09 PM
MoparFanatic21
What I did was just welded the nut to the bracket. That's how I got it out, and couldn't find a flag nut.
