Stereo wiring
Old Nov 14, 2017 | 09:12 AM
Ladale966's Avatar
Ladale966
Default Stereo wiring
Can anybody tell me how the speaker wires are routed on a 95 Dodge Ram 1500 single cab. I have the wiring diagram but there are no wires to the back speakers and I don't know where they were disconnected. Sorry if this is a duplicate post. My search button isn't working.
Old Nov 14, 2017 | 09:15 AM
Do you have a just the wiring diagram? Or do you have the service manual? If you want the manual, get one here. It will also show diagrams of where the harnesses are routed. (or, at least, supposed to be.....)
Old Nov 14, 2017 | 04:59 PM
Maximillio's Avatar
Maximillio
Assuming they didn't change such a simple cable routing between 95 and 01, the rear speakers run from the front, under the drivers side door area, to the drivers rear speaker, then up and over the the ceiling to the light, and then down to the other rear door speaker. At least this is how mine was.
Old Nov 14, 2017 | 07:35 PM
Swmpdnky's Avatar
Swmpdnky
If I remember correctly from doing my buddies they are routed underneath the kick boards and into the panels. Pretty simple but it’s a pain if you don’t remove the seat cause then you’re sliding them back and fourth to make room while you work. Hope this helps
