p1407
Old Dec 2, 2017 | 01:13 PM
Nodnarb14's Avatar
Nodnarb14
Default p1407
I've got a 2001 Ram 1500 5.9 magnum. and my check engine light came on. can anyone point me in the right direction to solve this problem
Old Dec 2, 2017 | 01:18 PM
Moved to correct section.
What's REALLY strange is, P1407 is "EGR out of test range." Doesn't seem so bad, does it? Trouble is, your truck shouldn't even HAVE an EGR valve.... so, of course it's going to be out of test range....... It ain't there. Unless you have the heavy duty version?
Anything been done to the truck recently, that may have prompted that code? Has the PCM been flashed with a different tune maybe?
Old Dec 3, 2017 | 04:50 AM
Nodnarb14's Avatar
Nodnarb14
I forgot to mention that my dodge is gasoline.
Old Dec 3, 2017 | 08:25 AM
Doesn't change anything. Your truck should not even have an EGR valve. What is the 8th digit of the VIN?
Old Dec 3, 2017 | 12:05 PM
Nodnarb14's Avatar
Nodnarb14
the eighth digit is Z
Old Dec 3, 2017 | 12:14 PM
Ok, that's the standard duty 360. No EGR. So, either the programming in the PCM is wrong, or it's the wrong PCM.... Do you know if it has been changed??
