Differences between ob1 and ob2 5.9 mangum?
Old Dec 18, 2017 | 12:30 PM
Djrcarter91's Avatar
Djrcarter91
Default Differences between ob1 and ob2 5.9 mangum?
Hey all, I am new so please be easy on me. I' David I own a 1995 ram 1500 2 door short bed 2x4. I have the 5.9 magnum paired with a 46rh. I have been looking everywhere to find the differences between a ob1 engine and a obd2 engine, can' seem to find anything. I hate havijng a obd1 its hard to find performane parts. So what is the difference between those two engine say a 1996 ram with the 5.9 and my 1995 with the same engine? I know the transmissions are different but as far as sensors efi injectors? Is there a big difference I mean I have been considering finding a 1997 donor ram with a 5.9 ripping enine harness and sensors and parts accordng such as tb but is there a diffeence in can end play crank position sensor cam? Can I take cylinder heads for a 1997 and fit them to the 1995? I just don't seem to find anything you know. Are all sensors different ? Coolant temp sensor? Any help with be very much appreciated. Thanks
Old Dec 18, 2017 | 01:06 PM
Torxhead's Avatar
Torxhead
Get the obd2 as it is a more advanced computer system. You will have to get the code reader for it of course.
Old Dec 18, 2017 | 01:35 PM
No real differences in the motors. Just the electronics that run them.
Old Dec 18, 2017 | 09:57 PM
silvermopar's Avatar
silvermopar
Not worth the hassle in my opinion. A few simple things like good tune up, exhaust, and gears will help both trucks. Beyond that and you've got a lot of money spent for a little more power.
Old Dec 19, 2017 | 10:19 PM
2bit's Avatar
2bit
I've read that the Harland Sharp 1.7 rockers help. $400 though. Some shorty headers and nice exhaust, 4.10 or 4.56 gears, E fans free up a few hp. It made a huge difference on my 95 when I changed the timing chain and fixed the plenum gasket.
The biggest difference is after 96 you can get an SCT tuner. I haven't seen anything for OBD 1 trucks. I don't know if we'd need a chip or different ECM or what.
