98 Ram 1500 4x4Transmission sticking
Old Dec 19, 2017 | 07:05 PM
TroyRuck82's Avatar
TroyRuck82
Default 98 Ram 1500 4x4Transmission sticking
i have a 98 dodge ram 1500 4x4 with the 5.9L the transmission seems to stick in 2nd gear sometimes 3rd. sometimes its fine other times I have to feather the gas or even shift into neutral and back to drive and that works everytime.. any ideas I have had the truck about 2 years now just recently started doing this.
Old Dec 19, 2017 | 07:56 PM
2bit's Avatar
2bit
Maybe the OD solenoid? I think there is a better fix than a new stock solenoid. Adjust bands and change fluid ATF +4 and filter while you're in there.
Old Dec 19, 2017 | 08:48 PM
TroyRuck82's Avatar
TroyRuck82
was doing some research and if definetly seems like a sensor or solenoid gonna start there I guess thinking new fluid wont be a bad idea either since ive never done it in the 2 years ive had it.
Old Dec 19, 2017 | 09:05 PM
If you are going in there after the electronics, replace ALL of them. Governor pressure sensor and solenoid, (there are the heavy duty borg-warner units out there, better than the stock pieces), and the O/D, and TCC solenoids. There are folks on ebay that sell complete sets, for around 200.
Old Dec 19, 2017 | 09:12 PM
TroyRuck82's Avatar
TroyRuck82
thank u definetly just wanna replace everything I need to while in there
Old Dec 19, 2017 | 09:14 PM
Don't forget to adjust the bands. Torque the adjusters to 72 INCH pounds, then back them off two turns, and tighten the jam nuts.
Old Dec 19, 2017 | 10:18 PM
TroyRuck82's Avatar
TroyRuck82
sweet thanks for all your help I'm pretty confident this should work hopeful anyway haha
