97 ram 2500 v10 wont start!
Old Dec 19, 2017 | 08:54 PM
David Micheal Morris's Avatar
Unhappy 97 ram 2500 v10 wont start!
I have a 97 dodge ram 2500 v10. It has always started really strong but after disconnecting the battery and reconnecting it it wont start! I even tried jumping it. When i jump it the lights n everything are strong but as soon as i go to start it everything goes dim and the truck just "glug glug glu...". Battery reads 14v before starting. I dont know what could have happened...
Old Dec 19, 2017 | 09:02 PM
You have a bad connection. Check everything you played with, make sure connections are clean, and tight.
Old Dec 19, 2017 | 09:59 PM
Torxhead's Avatar
Torxhead
The V10 takes a lot of amps to fire it up, so make sure your battery connections are good. Since the starter has the largest draw from the battery, I added a #4 wire from a starter bolt to the battery negative, plus I would suggest using copper or brass marine style battery terminals.
Old Dec 19, 2017 | 10:56 PM
2bit's Avatar
2bit
Maybe the cable itself is bad.
