What are EVAP canisters?
Old Nov 29, 2005 | 01:14 PM
  #21
steve05ram360's Avatar
steve05ram360
Default RE: What are EVAP canisters?
ORIGINAL: pirranah
also someone told me that the one on your frame is what catches over filled gas. the ones by your cai need to be higher than your gas tank because they can get gas in them and mess up, causing a code to show. so if they smell like gas that may be your prob.
if he used the brackets included with the K&N kit then he should be fine. my bet is he's got a split vacuum line somewhere. another thing you could try is to spray water from a water bottle or wd40 on the vacuum lines with the motor at idle... either one should change the idle if there is a leak.
My problem was with the hose running from the purge solenoid for the canisters on the leakage detection pump to the front of the throttle body. Once I got that hose tightened properly, the code was gone.
did you put a clamp on it? also did you have any pinging with your problem?
Old Nov 29, 2005 | 03:55 PM
  #22
01ramclassic's Avatar
01ramclassic
I've checked my gas cap, its not that but I know what you mean. My dad had a bad problem with his dodge doing that. I was thinking about using some dishsoap on the lines to find the leak if there is one? Or will that contaminate the lines? Is it going to blow bubbles or suck the soap into the line? Thats what I can't figure out.
Old Nov 29, 2005 | 04:12 PM
  #23
steve05ram360
anything you spray on it will get sucked in since it's a vacuum.
Old Nov 29, 2005 | 06:58 PM
  #24
01ramclassic
Is there any easy way to check without unhooking the canisters?
Old Nov 29, 2005 | 08:21 PM
  #25
Off_Road_Teacher's Avatar
Off_Road_Teacher
steve00ram360, I cut off the old hose and put on a new piece. The old piece was kind of cracked and stretched so I figured I would be better off if I just went with new. Never had a pinging problem even when the code was showing up.
Old Nov 29, 2005 | 08:26 PM
  #26
01ramclassic
hey, off_road_teacher, could you possibly identify some suspension parts that I got off a guys 2001 dodge 4wd?
Old Nov 30, 2005 | 12:05 AM
  #27
steve05ram360
what do you have?
Old Nov 30, 2005 | 12:14 AM
  #28
shott8283's Avatar
shott8283
i know what you mean by that braket for the CAI for the K&N... it was a super PINTA ..the directions for the kit where VERY poorly illustrated and written... i complain to K&N about it too... fortuantly i havnt had a problem with mine yet..
Old Nov 30, 2005 | 12:15 AM
  #29
Off_Road_Teacher
Post some pics of the parts.
Old Nov 30, 2005 | 03:35 AM
  #30
01ramclassic
ok, all of these parts came off a truck that a guy put a lift on.
[IMG]local://upfiles/21206/F0362E1BB85A491CBA35C2AD7FD6EA0A.jpg[/IMG]
