What are EVAP canisters?
Old Nov 30, 2005 | 03:36 AM
  #31
01ramclassic's Avatar
01ramclassic
Default RE: What are EVAP canisters?
I know that shocks are on the right, but I don't know the name of the stuff on the left it the pic above. Here is another pic of some stuff.
[IMG]local://upfiles/21206/6B765BF7B54949CD81AD84F9A322740D.jpg[/IMG]
Old Nov 30, 2005 | 03:38 AM
  #32
01ramclassic
and here is some rubber blocks too, pictured on the right I think...
[IMG]local://upfiles/21206/FC9AACC0D47A462281A4661ADDEBF8D1.jpg[/IMG]
Old Nov 30, 2005 | 03:42 AM
  #33
01ramclassic
and off course, the front springs....
I just need to correctly ID all the parts before I put them on ebay. I don't want to sound like a dumba$$ and just say "Dodge Suspension Part" and that be it, if you know what I mean, btw these all came off a 2001 dodge ram extended cab 4x4 gas burner.
[IMG]local://upfiles/21206/7161BE55ACE346DBB907CB02E1BAB0C0.jpg[/IMG]
Old Nov 30, 2005 | 03:49 AM
  #34
01ramclassic
so your saying that when I spray some wd-40 on the lines when idling the motor will fluxuat the rpms? If I do find a crack, can I just duct tape the line and call it a day? or will it come back to haunt me later?
ORIGINAL: steve00ram360
ORIGINAL: pirranah
also someone told me that the one on your frame is what catches over filled gas. the ones by your cai need to be higher than your gas tank because they can get gas in them and mess up, causing a code to show. so if they smell like gas that may be your prob.
if he used the brackets included with the K&N kit then he should be fine. my bet is he's got a split vacuum line somewhere. another thing you could try is to spray water from a water bottle or wd40 on the vacuum lines with the motor at idle... either one should change the idle if there is a leak.
My problem was with the hose running from the purge solenoid for the canisters on the leakage detection pump to the front of the throttle body. Once I got that hose tightened properly, the code was gone.
did you put a clamp on it? also did you have any pinging with your problem?
Old Nov 30, 2005 | 01:09 PM
  #35
steve05ram360's Avatar
steve05ram360
the parts you show are the contorl arms, they are only good for a stock to 3" height truck. you will be lucky to find a home for those parts, especially the shocks...
duct tape? uh NO... buy a new vacuum line... they're cheep.
