Transmission fluid check help
I’ve have been having problems checking my transmission fluid, originally I kept getting inconsistent readings (only on one side of the stick or none at all) and then I had a transmission cooler line blow. I’ve been filling it up and when I check it (idling in neutral) it reads there is none but when I check it when the truck is turned off it reads almost to the max. I’m pretty sure that’s because the torque converter fills up but I’m new to this stuff and wanted to make sure the reason the lines blew off was because they were old not because I over filled it. Thanks
