1999 dodge ram 1500 5.2
Old Jan 31, 2018 | 07:16 PM
Lester246's Avatar
Lester246
Default 1999 dodge ram 1500 5.2
I am trying to replace the transmission in my 1999 Dodge Ram 1500. The transmission part # isp52119820AA. I was told that the sensor on the casting must line up with the "magnet" or whatever on the torque converter. Can anyone tell me how to line up the 4 bolt torque converter with the gap on the transmission where the sensor goes? Also, I was told that the truck would not run without the sensor. Is that true as I am not getting any fire at the plugs. Why no fire?
Warm regards,
Ron
Hope this is the right section
Old Jan 31, 2018 | 09:10 PM
You want to be in the 2nd gen ram section, I'll move this post there.
No magnet on the torque converter.... there is a sensor on the bellhousing behind the passenger side head though. You want to REMOVE that before you remove/install the trans, else, you are likely going to be needing a new one. They tend to get bent/broken when you reinstall the trans.....
Welcome to DF!
