1999 3500 V10 crank position sensor needed
Old Feb 2, 2018 | 09:14 AM
poohbear62's Avatar
poohbear62
Default 1999 3500 V10 crank position sensor needed
I am stranded in Scottsdale, AZ and need a crank shaft position sensor. Where can I locate one? I ordered from rock auto and paid fed ex and they sent one that doesn't fit and it was labeled as a 1999 3500 V10 with the Mopar part number...
Old Feb 2, 2018 | 11:56 AM
Boxed wrong? Any numbers on the part itself?
Old Feb 2, 2018 | 03:23 PM
vmaxept's Avatar
vmaxept
I got this from amazon
Original Engine Management 96102 Crankshaft Position Sensor
Amazon Amazon
Have not tried to determine IF it will fit. Hope I never have to find out
Old Feb 3, 2018 | 10:13 AM
Jimythefan's Avatar
Jimythefan
That is not the correct sensor and will not mount properly. The 99 V10 sensor mounts to the right side of the block just in front of the motor mount. Here is the correct sensor for that year V10 on ebay. You might be able to use the part number to find it elsewhere quicker.
V10 crankshaft sensor
Old Feb 5, 2018 | 12:02 PM
vmaxept's Avatar
vmaxept
OK I see the difference. I will order the one from Ebay. The mount tab is different
As we all know it is difficult to find assorted parts for our v-10. Lot of wrong part numbers. I checked the pn for the one I bought - the searches show it fits the v10.
I dont need one now, just want a spare in case I ever do.
Thanks for the correction
