Shift problems 46RE Trans.
Old Mar 3, 2018 | 12:05 PM
Ramchu's Avatar
Ramchu
Have you adjusted the bands? Replaced any of the electronics?
Yes, governor pressure solenoid and sensor and filter.
Adjusted both front and rear bands.
Filled with ATF+4
Old Mar 3, 2018 | 01:40 PM
If it were a newer truck, I might suspect the output speed sensor.... but, I have no idea how much of a role it actually plays in the older ones.... What did you adjust the bands to?
Old Mar 3, 2018 | 03:01 PM
Ramchu's Avatar
Ramchu
72 in. lb. then backed off 2 full turns both front and rear.
Old Mar 3, 2018 | 03:12 PM
Well, that's correct.....
It would be interesting to do some data logging, and see what the PCM is thinking when it really doesn't want to shift.
Old Mar 3, 2018 | 03:21 PM
Ramchu's Avatar
Ramchu
Will just an OBD II scanner get that done ?
I have this one:
Amazon Amazon
I'll see if I can get the correct data log if it will work.
Old Mar 3, 2018 | 03:24 PM
Depends on what software you got with it. Most of the free ones either won't do logging at all, or, are rather limited on much they will log......
Old Mar 3, 2018 | 03:55 PM
Ramchu's Avatar
Ramchu
Torque Pro App.
Old Mar 3, 2018 | 04:00 PM
Ramchu's Avatar
Ramchu
I also have a friend that has one of these :
Amazon Amazon
That might get the logging that is needed
Old Mar 4, 2018 | 08:30 AM
I don't know if the torque app does that or not..... the scanner your friend has does, but, how much of the data stream, and how long it records, becomes the question. Wouldn't hurt to have a shot at it though
Old Mar 6, 2018 | 10:40 AM
Ramchu's Avatar
Ramchu
I've been searching and talking to the local transmission shop and have come up with this:
The delayed 2-3 shift or no 2-3 shift is actually a result of the inner lip seal of the direct clutch drum.
A delayed or no 2-3 shift is caused by a leaky direct clutch piston, inside the direct drum.
My truck is 22 years old and after changing the Governor Pressure solenoid and Governor pressure sensor and filter, this makes sense to me that the internal seals have hardened and/or cracked and are bypassing
fluid.
Any thoughts on this ?
