2001 dodge ram 1500 p0340
Old Feb 7, 2018 | 07:11 PM
Corey Tunstall's Avatar
Corey Tunstall
Default 2001 dodge ram 1500 p0340
My check engine light has been on for months with p0601 for bad pcm well it started getting terrible gas milage months agoa and got to the point where it began running rough and you could smell gas like it was just dumping too much gas. Replaced pcm and now when i start it up the code p0340 comes on? Could this have been from how it was acting before? Any ideas on what all i should look at or replace? Any info would help thanks!
Old Feb 7, 2018 | 08:28 PM
p0340 Camshaft position sensor circuit malfunction.
Might be bad wiring, might be bad sensor, might be bad PCM..... you can check the wiring, maybe replace the sensor, and see if that clears it up. Best figger it out before the warranty on the PCM runs out.
Old Feb 7, 2018 | 08:33 PM
Corey Tunstall
Im leaning to them sending me a bad pcm because the p0601 code is back on with this one!
Old Feb 7, 2018 | 08:38 PM
Yeah, that's generally a fatal flaw...... Memory error in the PCM.
Old Feb 7, 2018 | 08:41 PM
Corey Tunstall
I guess ill just have to get another one from them but ill probably replace that sensor too and see if that helps with the one code.
Old Feb 7, 2018 | 08:42 PM
Corey Tunstall
Could the pcm being bad and the way it smelled and seemed to be dumping gas and idiling erratic caused that sensor to eventaully malfunction?
Old Feb 7, 2018 | 08:43 PM
If you are getting the 601, ignore everything else until that one is solved.
Old Feb 7, 2018 | 08:46 PM
Corey Tunstall
Will do ! Ill call tomorrow and talk to them! Thanks for the input!
Old Feb 7, 2018 | 08:52 PM
Let us know what ya find out.
