Need help please
Old Feb 12, 2018 | 03:22 PM
Ted Ratterman's Avatar
Ted Ratterman
Default Need help please
Ok so I have a 1996 dodge ram 1500 5.2 been having some issues with losing antifreeze and then a valve spring broke so I went a head and took the heads off and put new gaskets all the way up got it back together no fire so I started replacing stuff first coil crank sensor swapped relays around checked grounds and I can't get it to fire please help I need my rig to go back to work
Old Feb 12, 2018 | 04:48 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
What aren't you getting? Are you getting spark? Are you getting fuel? Hear the fuel pump when you turn the key?
Old Feb 12, 2018 | 05:25 PM
2bit's Avatar
2bit
Did you remove the distributor? And what's mentioned above.
Old Feb 12, 2018 | 06:23 PM
Ted Ratterman
Default No
No I did not
Old Feb 12, 2018 | 06:25 PM
Ted Ratterman
Not getting fire getting fuel
Old Feb 12, 2018 | 07:23 PM
MoparFanatic21
So no spark?
Old Feb 12, 2018 | 09:02 PM
true blue's Avatar
true blue
Have you tried replacing the coil yet? If there's any way you can test to see if the coil is getting "instructions" to fire from the ECM, usually a cheap volt/ohm meter will do the trick...all it's gotta show is some kinda voltage deflection whilst you're cranking the pickup.
Old Feb 12, 2018 | 09:23 PM
Even a test light would work.
