Swapping Dana 70 for Dana 60
Old Feb 18, 2018 | 01:18 PM
Mark S.'s Avatar
Mark S.
Default Swapping Dana 70 for Dana 60
I have a 96 Ram 2500,4WD, 5.9L gas with 8800GVW and camper spring option. The rear differential is beyond normal repair (diff. case and carrier damaged) for a reasonable cost. I located a Dana 70 with Power Lock option for a good price. I have searched the forum and it appears to be a direct bolt in swap, except for drive shaft yoke. Does anyone have the specifics on this swap, I like the idea of the power lock diff. I am not looking to do a lot of modifications, otherwise I will continue to look for a Dana 60, who knew Dodge had so many axle combinations.
Old Feb 18, 2018 | 02:12 PM
AtomicDog's Avatar
AtomicDog
Do you know what year Dana 70 you are planning to use and did it come out of a Dodge truck? If it came out of a second gen Dodge truck, it should work fine. If the yoke is different, there should be a conversion U-joint available.
Old Feb 18, 2018 | 02:23 PM
Mark S.'s Avatar
Mark S.
The Dana 70 is out of a 97 Ram 2500 with diesel engine and auto trans. The ratio is actually 3.54, I think because of the power lock diff. case.. I think the 3.54 rear and 3.55 front ratios will be compatible.
Old Feb 18, 2018 | 03:11 PM
Should bolt right in, and hook right up, aside from the u-joint, and even that may be the same.
Old Feb 18, 2018 | 03:13 PM
AtomicDog's Avatar
AtomicDog
It's likely slightly different due to the larger ring gear size of the Dana 70, not due to the Power Loc. Using that Dodge Dana 70 should be a pretty straight forward swap. Is your truck 4WD or 2WD? If 4WD, the front gearing ratio should match, however, a .01 difference is likely fine.
Old Feb 18, 2018 | 03:15 PM
AtomicDog's Avatar
AtomicDog
I have a Dana 70 sitting out back. I'll check to see if that yoke is different from a Dana 60 and let you know.
Just checked and the yoke sizes are the same.
Last edited by AtomicDog; Feb 18, 2018 at 08:40 PM. Reason: Checked the yoke sizes
