U joints?
Old Feb 26, 2018 | 06:01 PM
Joelmichelle#1's Avatar
Joelmichelle#1
Originally Posted by Moparite
Call your local truck parts store, Most auto parts stores don't carry them. They may not have what you need but can get them.
What's an example of a truck parts store cuz I search truck parts storea near me but only NAPA and a bunch of tractor trailer parts stores
Old Feb 26, 2018 | 11:24 PM
Ramman18's Avatar
Ramman18
Originally Posted by Ramman18
Nice and thanks! Happy to help. There are different sizes from axle to drive shaft. I have them written down in my Chilton's but can't find it at the moment. I do know the fronts are 5-760x. The rear shaft uses two different ones and the front shaft uses three of one size.
http://www.dennysdriveshaft.com/p132...rsal_join.html
Look here for the sizes! I always have to go a driveline shop to get mine as auto stores don't carry them (Spicer). Avoid anything but Spicer!
I'll just quote myself. . .
Where are you located? You need a semi-truck axle/driveline shop. They are located in industrial areas of cities. Or just order from the link I gave.
Old Feb 27, 2018 | 07:13 AM
Joelmichelle#1
I'm located in Massachusetts i usually do order from those sights like the one you gave but the other guys above you said it's smarter to get it from a driveline shop instead of online but the prices for online parts say otherwise
Old Feb 27, 2018 | 10:26 AM
Ramman18's Avatar
Ramman18
Haha, get them wherever you want to!
All we recommend is that you stay with the OEM Spicer sealed joints for the best results.
Old Feb 27, 2018 | 03:27 PM
Joelmichelle#1
Sounds good thanks for the response everyone
Old Mar 1, 2018 | 08:39 AM
jlake4130's Avatar
jlake4130
You can go to the local parts store to verify the sizes you will need. it helps if you measure the old joints (cap dia, cross section sizes). then go online and buy the correct spicer joints. Like mentioned, only by spicer joints.
Front axles shafts are easy - 5-760X
The driveshaft (front/rear) sizes can vary, thus the measuring...
Old Mar 1, 2018 | 02:02 PM
2bit's Avatar
2bit
5-3226x is the axle shaft joint for the 1500. It has the needle fitting in the cap so you can grease it once it's installed.
