Transmission leaks
Old Feb 26, 2018 | 10:50 PM
Sco's Avatar
Sco
Default Transmission leaks
I have a 96 dodge ram 1500 4x4 5.2 automatic was leaking between motor and Tran changed the seal but still pouring fluid when you put into drive any thoughts
Old Feb 27, 2018 | 05:10 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Front pump?
Old Feb 27, 2018 | 03:49 PM
Sco's Avatar
Sco
Front pump?
it don't leak in reverse I don't know I'm just trying to figure it out could it be the solenoids?
Old Feb 27, 2018 | 06:19 PM
Not dumping fluid outside the trans. Either you seal is bad, or the pump seal is bad. Either way, trans needs to come out.
Old Feb 28, 2018 | 02:51 AM
MoparFanatic21
He could pull the engine as in my opinion it's easier to pull the engine then the trans
Old Feb 28, 2018 | 10:47 AM
On a 4x4, I would agree with you. Less messy too.
