blocking the radiator???
Old Dec 1, 2005 | 02:50 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: blocking the radiator???
When I was in Alaska, almost every car and truck in the little town I was in had radiator covers. The Rams had nice ones made of vinyl or faux leather looking material (like a tonnau cover type material) that could be unzipped in sections (kinda like the big rigs do) in case you needed a lot of air, a little bit of air, or no air to pass through. They looked very good. YOu should look for something like that instead of cardboard.
Old Dec 1, 2005 | 02:52 AM
shott8283's Avatar
shott8283
thanks for the idea...ill look around for them.... they sound better then a cheezy cut up pizza box... no pun intended...hahahaha... but ive been lookin for block heaters and im gonna go to autozone and get an oilpan block heater ... looks the easiest to install and more reliable... ill post my results after a few test runs!!!!! thanks silver!
Old Dec 1, 2005 | 02:56 AM
REDKNOB's Avatar
REDKNOB
I honestly do not know the capacity. About 2 months ago I bought 3 gallons (and an equal amout of distilled water) and flushed and filled my truck, the wifes van, the daughters car and my generator. I still have a little less than a gallon, mixed, left. I mix mine at a 50/50 mix but you could go a little more on the antifreeze because of your more extreme temps.
Old Dec 1, 2005 | 03:05 AM
shott8283's Avatar
shott8283
anyone got a clue where i can look up the nice radiator covers like silver mentioned? having a hard time lookin up the topic on yahoo.
Old Dec 1, 2005 | 03:06 AM
shott8283's Avatar
shott8283
thanks red.... ill stop by dodge tomorow and ask the techs... maybe they might know something...usually they dont though good fellas and autozone know a bit or 2... haynes might know too... ill see ill post my findings as usual
Old Dec 1, 2005 | 04:27 AM
01ramclassic's Avatar
01ramclassic
I'd check on ebay shott.....
Old Dec 1, 2005 | 12:36 PM
Dodgeramman's Avatar
Dodgeramman
ORIGINAL: shott8283
dodgeram man... your from ny? we saposed to get bashed with some this weekend ..from what i hear...
About 20 minutes from Buffalo down Rts 5 and 20. Yeah we are going to get blasted again tonite and tommorow and I am supposed to drive to Ellicotville with a bus tommorow night. Let me know how that heater works and if you can find a rad cover.
Old Dec 1, 2005 | 01:36 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: shott8283
its starting to get really cold up here in western ny... the other day me and the wife were coming home from the Sabres game and after about 30 mins of driving on the thruway..
Sabres fan... right on. Sharks (my favorite team) gets to visit your "house" tomorrow night. Should be interesting... we just aquired Joe Thornton from Boston...
on your non-heatup problem, another thought might be an electric fan... Flex-a-lite makes a 5000 cfm double that should work good, or a viper fan setup... with the right controller it wont turn on until 195 and it'll have better warmup times from what I hear.
Old Dec 1, 2005 | 01:56 PM
securtis12's Avatar
securtis12
Just a comment on the block heater they are great for overnight but will not help you with heating your truck while you are going. I agree with others I think your thermostat may be going bad. My son in colorado had a similar problem and it was his thermostat and his waterpump was weak (did not push the fluid into the heater core) You could also have a partialy clogged heater core (working on warmer days it would take less to heat) a good flush may fix that but I would err on the side of caution and change the thermostat while you were at it.
Old Dec 1, 2005 | 03:12 PM
hawkeyedodge's Avatar
hawkeyedodge
In Iowa it gets pretty friggin cold too. I used to have to put cardboard in front of the radiator on my Cj-7. Havnt had to yet with my dodge though, however this morning its about 5 degrees outside and Ive seen 3 or 4 newer GMC's already with cardboard over the grills.
