97 3/4ton Front driveshaft bolts?
Old Mar 3, 2018 | 07:03 PM
smoky614's Avatar
smoky614
Default 97 3/4ton Front driveshaft bolts?
i know its a oddball question, just hoping one of yall can help. im bout to go lookat this truck but it has the front driveshaft took out. he said he had someone change a u-joint in it and they never put it back in.And apparently he lost most the bolts but has it sitting there with the new u-joint in it, just needs thrown in. So what i was wondering is if anyone knows what i need to hook it back up. its been awhile but if im not mistaking it uses clamps towards the axle and bolts straight to the transfer case(correct me if im wrong). if thats the case i should be able to pick up the clamps and bolts from autozone. but id still need to know the size of the bolts to the transfercase, probably have to go to fasentals or ace for them. any help is appreciated, thanks.
Its a 97 ram 2500 reg cab. if there the same one the 1/2ton(which i doubt) that would be awesome. i could just take mine off and take them with me!
Old Mar 4, 2018 | 08:28 AM
Parts manuals are available in the faq/diy section, check there, should have dimensions for the bolts.
Old Mar 4, 2018 | 10:32 PM
smoky614's Avatar
smoky614
Thanks man, found what i needed. Thats a nice little set up yall go on here.
Old Mar 5, 2018 | 09:11 AM
We've been workin' on it for a while now.
