tranny issues, band adjusment?
Old Mar 10, 2018 | 12:00 PM
smoky614's Avatar
smoky614
Default tranny issues, band adjusment?
I jus t got a 01 ram 3/4ton gas, but it has some tranny issues. Im not sure if its stuck in third or just not getting into overdrive. Im running 2800rpms at 55mph. So im wondering if it might be something as simple as a band adjustment or if the trannys junk, what do yall think?
Old Mar 10, 2018 | 12:01 PM
Sounds like you aren't getting O/D. Any codes from the PCM?
Old Mar 10, 2018 | 12:04 PM
smoky614's Avatar
smoky614
check engine light is on, havent had it checked yet. ill get that done today. forgot to mention, turning overdrive on or off doesn't change anything.
Old Mar 10, 2018 | 12:06 PM
See what the PCM is whining about. Take it from there.
Old Mar 10, 2018 | 02:14 PM
smoky614's Avatar
smoky614
well, had her checked out. only code on there was for the spark plugs(aint gonna lie, thought there be alot more!) But i did forget to mention that the guy i got it off of just put the tranny in last week, said he got it from a guy online who was about to junk his truck(so it very well could just be a bad tranny). but he forgot a stabilizer bolt and left a few pan bolts a bit loose(tightend them up and made sure the fluid was topped off). So i dont know if he could have left something unplugged, or not hooking the linkage up right(there is a little play in the shifter) would cause an issue. (dont know a lot about trannys if you cant tell!)
Old Mar 10, 2018 | 07:24 PM
Any idea what year the trans donor was?
Old Mar 12, 2018 | 12:26 PM
smoky614's Avatar
smoky614
Just got ahold of him, it came from a 98 ram 1500 4x4(go figure it came from the same thing I was planning on swapping for!) You think it might be the electronics in the pan?
Old Mar 12, 2018 | 12:27 PM
If they weren't changed to match those for the year of the truck, they WILL cause problems.
Old Mar 12, 2018 | 12:31 PM
smoky614's Avatar
smoky614
Think it'll cause that kind of problem, or is your guess as good as mine?
Old Mar 12, 2018 | 08:23 PM
Wrong electronics will disable O/D. The PCM thinks the trans is too hot, and shuts it off. It *should* also turn on the trans temp light in the dash, but, not always.
