Cylinder Misfire
It may be inconsistent signal from the cam, or crank sensor too...... Unfortunately, it has been demonstrated that the crank sensor isn't simply a binary works/doesn't work. A weak signal can give you a weak spark on any individual cylinder. You wouldn't think it could work that way, but, another member proved his point with an oscilloscope.... That was highly enlightening.
