96 5.9 Occasional Hard Start
Old Mar 17, 2018 | 11:58 AM
Ramchu's Avatar
Ramchu
I'm not a fan of Sea Foam products, but I did just run a couple of tanks gas with Lucas Injector cleaner
thru it.
Thanks for the suggestion.
Old Mar 23, 2018 | 09:50 AM
Ramchu's Avatar
Ramchu
Well I do believe that the pump in the fuel pump assembly module that I put in about 20 month ago
is going bad causing the occasional longer crank slow start issue.
It's making a louder strange sound than normal.
Has anyone changed just the pump in the module assembly with any success ?
I can get just the pump off of RockAuto for about $ 45 or a complete module for about $ 120 +
Old Mar 23, 2018 | 01:57 PM
Going cheap is why you are replacing it again, after less than two years. Want to fix it, and probably never have to worry about it again? Get a delphi, or denso pump module. Yes, they are more expensive, but, in this case, you aren't just paying for a name. The parts are MUCH higher quality.
